Rotor Dynamics Analysis Capabilities – AxSTREAM® Introduction
Without proper rotor dynamics analysis, rotating machinery is at a higher risk of failure during operation. It is with this in mind that rotor dynamics software is arguably one of the most important tools in the turbomachinery design process.
The AxSTREAM® RotorDynamics module is a software tool that can account for a number of things such as bearing characteristics, rotor imbalance and general excitation, critical speeds and whirl frequencies, and much more.
Rotordynamics
Applications
The AxSTREAM® RotorDynamics software module has a number of different uses. This includes but is not limited to:
  • Jet engines
  • Cooling systems
  • Pumps
  • Compressors
  • Fans
  • Generators
  • Wind turbines
  • Steam turbines
  • Centrifugal compressor turbochargers
  • Gas turbines
  • Electric motors
Rotordynamics-application
Rotors and rotor trains are modeled as cylindrical or conical beam elements (plain or hollow) using a FEM (Finite Element Method) solver and mass-inertia elements can be used to simulate disks, roots, blades, impellers, probes, etc.
Scope of Analysis
Using AxSTREAM® RotorDynamics, different types of rotating machinery analysis can be performed:
  • Static deflection analysis – Allows calculating deflection of the rotor under its own weight as well as reaction on each of the bearings in the system
  • Lateral critical speeds analysis for fixed and variable support stiffnesses
  • Unbalance response analysis
  • Whirl speed and stability analysis
  • Train torsional modal, transient, harmonic and reciprocating machines analysis
  • Vibration analysis
  • Fluid film bearing analysis
  • Rotor balancing analysis
Rotordynamics-analysis
The program’s post-processing capabilities allow obtaining information about the rotor-bearing-support system like the following:
  • Static deflection form
  • Stresses, forces and moments throughout the machine
  • Critical speed mode shapes
  • Critical speed map
  • Rotor response plot
  • Amplification factor and separation margin based on provided unbalance and damping characteristics, as required by API standards
  • Stability plot and Campbell diagram for both lateral and torsional analysis
  • Torsion natural frequencies
  • Transient torsional responses torque and stresses
Rotordynamics-scope-analysis
For more information on rotor dynamics, watch an introduction and short demo to our rotor dynamics software
Video Player
00:00
31:44
Interested in learning more? Register for our full rotor dynamics online video course below!
    • AxSTREAM® Software Platform
      The AxSTREAM® software platform for multidisciplinary design, analysis and optimization provides an integrated and streamlined approach to turbomachinery design. This best-in-class software solution encompasses the complete process for radial, axial ...
    • Bearing Calculation and Analysis Capabilities – AxSTREAM®
      Introduction Rotor dynamics analysis would neither be complete nor reliable without accurate modeling of bearings. The AxSTREAM Bearing™ module is used to determine hydrodynamic and mechanical characteristics for different types of hydrodynamic ...
    • Axial Turbine Design Software – AxSTREAM® Platform Overview
      The AxSTREAM® platform for multidisciplinary turbomachinery design, analysis and optimization software tools provides a fully integrated and streamlined solution for the complete flow path design process of axial turbines. Starting from the ...
